Add-on Sales page
This page contains the online version of the manual that comes with the PLL02A-1 add-on board
Introduction
It is illegal in many countries to transmit outside of the normal CB band, this board is to be used for RX only, do not transmit out side of the legal band, you are responsible for the manner in which you use the conversion board.
This board will increase the possible frequency range by 4 bands, as follows:
If the board is installed on a 40 channel radio you will get low, mid (FCC), high, NZ, UK and a 10kHz shift on all bands ! (assuming that the radio is broad band enough to be able to produce the full range), that is an extra 4 bands !
If the board is installed on a Export type 200 channel radio you will get L-L-low, L-low, low, mid (FCC), high, H-high, H-H-high (not on all models), NZ (down 63 channels), UK (up 64 channels) and a 10kHz shift on all bands !
It is possible to enable the NZ and UK bands when in the range of normal bands (not on all models) to go up by 64 channels or down by 63, so on a 5 band model that will give you coverage from 25.435 - 28.905 (assuming that the radio is broad band enough).
Of course you do not need to enable every option on the board, you can choose which ones you wish to use, if you only want the UK band that is fine, or if you only want to have the down 1 band and up 1 band with +(-)10 kHz shift that is fine too, it is up to you.
I have built as much data into the EPROM as I could fit on it so that there are lots of options that can be used. This board is not suitable for some radios, please read further in this manual to see if your radio can use this version of the board, (I can make custom boards at an additional cost).
General Information
A degree of electronic skill is required to install this expansion board, also the radio may need to be tuned or broad banded to allow for the extra frequency coverage that this board will allow.
I have made a quite simple installation look complex, please do not be concerned about the complexity of this manual, once you know the binary code range(s) used in your radio you just cross check it against the programming chart I have included, this will show what options and programming requirements there are for it.
I have tried to include as much information as possible in this manual to try and cover all possible requirements and radios, I am sure that there will be times when some people will need more information or assistance and when this occurs I can be contacted either through my web site at https://www.radiomods.co.nz/ or by emailing me.
This board was designed to convert radios with these PCB numbers:
And others as long as the binary codes are correct (see below).
For the board to function correctly the PLL must be using one or more of these binary code ranges:
300-256 (CH1-CH40)
255-211 (CH1-CH40), this is the most common code.
210-166 (CH1-CH40)
224-268 (CH1-CH40) or 253 for 23 CH radios.
To work out the binary code just measure the voltage on pins 15 through to 7 of the PLL with the radio on channel 1 mid (FCC) band.
For a code of 300 pins 13,12,10 and 7 will be at 5 V. Pins 15,14,11,9 and 8 will be at 0 V.
For a code of 255 pins 15,14,13,12,11,10 and 8 will be at 5 V. Pin 7 will be at 0 V.
For a code of 210 pins 14,11,9 and 8 will be at 5 V. Pins 15,13,12,10 and 7 will be at 0 V.
For a code of 224 pins 10 and 7 will be 5 V. Pins 15,14,13,12,11,9 and 8 will be at 0 V.
Some radios use two sets of codes depending on the band, check the codes again on one of these bands, either: 255-211 on bands A,C,E and 210-166 on bands B,D,F. or 255-211 on bands C,D,E and 300-256 on bands A,B.
NOTE: some radios are not marked as A,B,C,D,E they may be L-Low,Low,Mid,High, H-High etc.
The extra coverage that should be gained is as follows:
For mostl radios:
Down 1 band, Up 1 Band, New Zealand 40 Channels (down 63 channels), UK 27/81 Channels (up 64 channels without Alpha channel hops) and +10kHz shift on all bands,.
The NZ and UK bands are operated from the mid (FCC) band (with the exception of radios that use the PTBM133A4X board, the NZ band is operated from the low band).
Exceptions to this are radios that use the code range of : 224-268, they will get a -10kHz step instead 210-166, they will not get the Up band.
Example of possible coverage
When I installed this board in my Superstar 2000 (PTBM131A4X) I got the following coverage:
25.615 - 26.055 L-L-Low- NEW band With Down band on
26.065 - 26.505 L-Low -A band
26.515 - 26.955 Low -B band
26.965 - 27.405 Mid, FCC -C band       Normal bands
27.415 - 27.855 High -D band
27.865 - 28.305 H-High -E band
28.315 - 28.755 H-H-High -NEW band With Up band on
25.435 - 25.875 L-Low NZ band -NEW band With NZ band on band A
25.885 - 26.325 Low NZ band -NEW band With NZ band on band B
26.330 - 26.770 NZ band -NEW band With NZ band on, clarified
26.785 - 27.225 High NZ band -NEW band With NZ band on band D
27.235 - 27.675 H-High NZ band -NEW band With NZ band on band E
THESE BANDS DO NOT HAVE THE Alpha CHANNEL HOPS !
26.705 - 27.095 L-Low UK band -NEW band With UK band on band A
27.155 - 27.545 Low UK band -NEW band With UK band on band B
27.601 - 27.991 UK band -NEW band With UK band on, clarified
28.055 - 28.445 High UK band -NEW band With UK band on band D
28.505 - 28.895 H-High UK band -NEW band With UK band on band E
Also there is the +10 kHz shift on all bands.
Of course there is overlapping of most of these bands with the original frequencies but I thought you may like to know what it is capable of !
The most interesting part is when on the UK band as it gives 40 consecutive channels without the Alpha channel hops, but of course the +10kHz shift can sort those out for you !
Detailed Information
Here is a list of radios that I designed this board for, I got the binary code information from the great books written by Lou Franklin (http://www.cbcintl.com), the list is probably much bigger than this as the only critical factors are that the radio uses the correct binary codes and that the board will physically fit inside the radio.
PTBM125A4X / PTBM131A4X
Colt 1600DX, 2000DX, Hygain 8795 (V), Layayette 1800, Midland 7001 Export, Pacific 160, Superstar 2000, Tristar 777, 790.
PCMA001S
Alan 88S, Argus 5000, Cobra 148GTL DX (fake),CTE 88S, Colt 2400, Falcon 2000, Lafayette 2400FM, Mongoose 2000, Nato 2000, Palomar 2400, 5000, Starfire DX, Superstar 2200, Thunder 2000, Tristar 797, 848.
PTBM 133A4X
Ham International Concorde III, Jumbo III, Multimode III, Major M788.
PTBM121D4X
Cobra GTL150, Colt 320DX, 320FM, 1200DX (Excalibur), Ham International Concorde II, Jumbo II, Hygain 2795, 2795DX, Intek 1200FM, Lafayette HB870AFS, Tristar 747.
PTBM027AOX, PTBM033AOX, PTBM036AOX, PTBM038AOX, PTBM039AOX
Delco (GM) CBD-10, 1977/78 series, GE 3-5810B, Hygain 681, 682, 2679, 2679A, 2680, 2681, 2682, 2683, 2701, 2710X, 2716, 2720, 3084B, Kraco KCB2310B, 2320B, 2330B, Lafayette Com-Phone 23A, HB650, HB750, HB950, LM400, Micro 223A, Telsat 1050, Midland 13-830, 13-857B, 13-882C, 13-888B, 13-955, Pearce Simpson Tiger 40A, Tiger MKII, RCA 14T300, 14T301, Robyn GT410D, SX401, SX402D,Sears 242.3816, 60000, Truetone MCC4434B-67, CYJ4732A-77.
Please note that I am not able to test this unit in every make and model, but as long as the binary codes match the ones I listed you will have no problems.
OK, now on to the nuts and bolts (or is the resistors and capacitors ?)....
Installation Procedure
Be careful when handling the Eprom, it is a static sensitive device and may be damaged if care is not taken to avoid static build up, whenever you pick up or put down the device ALWAYS touch the surface first so that static does not pass through the device, the best thing is to use a antistatic wrist strap at all times.
  1. Check for the correct binary code at the PLL pins, see note earlier in manual.
  2. Decide what bands you require the board to produce (see note below), set the jumpers and cut the tracks on the EPROM board and to match.
  3. Decide how you are going to control the new bands, existing panel switches, new toggle switches, replacing the rotary band switch (only for pros !) etc.
  4. Cut the tracks that go to pins 15 through to 8 (or 7, see note on next page first !) to isolate them from the channel selector and jumper connections.
  5. Solder the ribbon cable to the PLL pins (D0-D7, see picture later) and to the channel selector side of the cut tracks (A0-A6, see picture later).
  6. Solder the EPROM board earth (0V) to pin 16 of the PLL of the any other good earth point on the main board.
  7. Solder the +12V wire to the main radio supply, make sure that it is from after the on/off switch so that the board is not powered when the radio is turned off., On the PTBM131A4X board there is a PCB pin on the right hand side about half way back, it is marked as Ò10Õ and it is next to Q26.
  8. Connect the board to the switches to select the required bands and functions.
  9. Go back to step 1 and double check everything on each step.
  10. Triple check everything, I mean it !
After doing this you should have the board connected to +12V, earth, 8 outputs from the EPROM to the PLL (D0-D7), 7 inputs from the cut tracks on the channel selector side to the inputs of the EPROM (A0-A6), the EPROM control lines connected to your switches:
A7 = DOWN band,
A8 = UP band,
A9 (+A7/A8) = NZ/UK,
A10 = +10kHz step.
Some radios may have slightly different programming, for radios with codes of 224-268 here are the differences:
A9 = UK band (others use A9 + A8),
A9, A8 and A7 = NZ band (others use A9 + A7),
A7 = UP band ,
A8 = DOWN band,
A10 = -10kHz
See the programming chart later in this manual for a completely comprehensive listing of control functions and binary codes required.
Testing and additional info
11. Turn the radio on and test everything thoroughly, all bands, both existing and new, Down band, Up band, NZ/UK and 10K shift on each.
Radios that use the PTBM133A4X board will need to activate the NZ band from band B (low band) and the UK band from band C (mid, FCC band) instead of NZ and UK being from the mid (C, FCC) band
Radios that have a code range of 255-211 and 210-166 (usually six band models) will not get any UP bands when using the 210-166 codes (bands B,D,F) , this is due to running out of programming options, also when on bands B,D and F EPROM pins A7 and A8 need to be pulled high at all times, this can easily be done using diode steering:
Attach a diode to each of the band positions for B,D and F, so that when the radio is in any of those bands the diodes will pass a voltage through a resistor to drop the voltage to the EPROM pins down to about 5 Volts (this is very important !), see the diagram for more information.
12. Tune or broad band anything that needs adjusting (see tips later in manual).
13. If all is OK and you did not make any mistakes, CAREFULLY heat shrink the EPROM board with the tube supplied, do not apply too much heat.
14. Close up the radio and enjoy your new frequencies !
Pictures and advanced info
This picture shows the EPROM board wiring diagram with its inputs (A0-A6) its programming/switch inputs (A7-A10, (or A l l if fitted with a 2732 EPROM) and the 5V, 0V rails), its outputs (D0-D7) and its power supply connections (+12V and 0V).
This diagram shows the diode steering that is required for use with radios with codes of 210-166 on bands B,D and F.
This picture shows the PCB jumpers that are on the board, as you can see the tracks narrow at a point where they are normally tied to ground, if you are not going to use 1 of the control lines leave the track intact, but if you are going to use 1 or more lines cut the track for the pin you are going to control.
For example, the top one is A8, which is used for the UP band, if you did not want to use the UP band (or UK band as it uses that pin also) you would not have to do anything.
But if you wanted to use the UP (or UK) band you would need to cut the track that goes between the pin and the earth track (the big thick vertical one on the right), then you can solder the control wire into the provided hole and attach the 0V and 5V control wires for it as well, the 5V rail is the one going down the left side, the 0V is the one that is horizontal above D7 and connects to the main earth track, you can also see the pads that allow the pins to be tied high without having to attach jumper wires if a pin needs to be programmed to be high all of the time, you will notice that for boards using a 2716 EPROM (most of them) the A11 track is cut and the pin is pulled high.
The picture below shows the pin-outs of the PLL as viewed from the track-side of the PCB, pin 1 of the PLL is at the top left corner and has a 5V supply going to it.
These pictures show various methods of band selection, any one of the switches can be omitted, the NZ/UK switch can be used without an Up / Down band switch, also you can have it set up so that it automatically turns on the Up (for UK) / Down (for NZ) band when you activate it (required for it to work), as longs as diode steering is used to select either the A7 (for NZ) or A8 (for UK) lines when activated.
Notes
PLL Pin 7 switching
For radios with a code range of 255-211 ONLY on all bands you can just attach pin 7 directly to the switch wire that goes to the EPROM for the Low band, this pin must be high on the Low and NZ bands and low on all others, this does it nicely on these radios !
For radios with codes of both 300-256 (L-Low and Low bands) and 255-211 (Mid,High and H-High bands) just leave the track alone do not cut it as it will give the correct voltage when needed anyway !
For radios with a code of 224-268 you must do a little extra work, when in normal bands (all extras turned off) pin 7 must be connected as normal as it changes from high to low in the normal range of codes, when the DOWN or NZ band is activated the pin must be low all of the time, so it must be disconnected from the track and pulled low, but when in the UP or UK bands it must be pulled high instead.
Radios that have a code range of 224-253 can just cut the track and control it by pulling it low in the DOWN,NZ bands and high in the UP,UK bands.
Broad banding
Most radios will not need it to be done, but you may need to, an easy way is to tune the radio for the upper frequencies (but as low as you can without problems) and then add the circuit below to the low bands to extend the tuning range of a problem tuning can, the PTBM131A4X board uses this type of circuit on its TX mixers !
Clarifier slide increase
The clarifier on most of the SSB radios gives about 5kHz of slide, which is enough for most purposes, but if you want to add a little more slide then add a 4.7 uH RF coil to the varactor diode, on the PTBM125A4X, PTBM131A4X and PCMA001S it is D6, on the PTBM133A4X it is D7, on the PTBM121D4X it is D1 on the crystal oscillator board (PTOS110AOX)
NATO 2000, UK FM Band
The NATO 2000 already has the UK40 as part of its own band structure,the binary code range of the UK FM band is 255-216 so it will work without any problems make sure that the EPROM is placed between the PLL and the two proms (IC601 and IC602), then just have the EPROM selected with normal mode (no extra bands enabled) to use the UK band, it will be unaffected by the presence of the EPROM board, but you will still gain a 10K shift, of course you can still use the UP and DOWN bands as well if you like.
+10kHz shift
For The Down band (and on the L-Low and Low bands of radios using a code of 300-256) the +10Khz shift will not work on Ch 40, this is due to the code changing from 8 bits to 9 and it is not worth the extra effort and expense for the sake of one channel that you can get by going to channel 1 on the next band up anyway !
EPROM band and function selection codes and programming
This section show you all of the possible programming arrangements with this EPROM and what input codes allow which outputs from the EPROM board, just look up the input code range(s) that your radio uses and look at the possible operating bands and programming information for the board.
Input code
A6
A7
A8
A9
A10
Output Code
Band
255-211
1
0
0
0
0
255-211
Normal
1
1
0
0
0
300-256
Down
1
0
1
0
0
210-166
Up
1
1
0
1
0
319-275
NZ
1
0
1
1
0
191-151
UK
1
0
0
0
1
254-210
Normal +10kHz
1
1
0
0
1
299-256
Down +10kHz
1
0
1
0
1
209-165
Up +10kHz
1
1
0
1
1
318-274
NZ +10kHz
1
0
1
1
1
190-150
UK +10kHz
300-256
1
0
0
0
0
300-256
Normal
1
1
0
0
0
345-301
Down
1
1
0
1
0
319-275
NZ
1
0
0
0
1
299-256
Normal +10kHz
1
1
0
0
1
344-300
Down +10kHz
1
1
0
1
1
318-274
NZ +10kHz
210-166 *
1/0
1
1
0
0
210-166
Normal
1/0
1
1
0
1
209-165
Normal +10kHz
* Important note !
A7 and A8 need to be pulled high at all times when in the 210-166 code range!
Input code
A6
A7
A8
A9
A10
Output Code
Band
224-268 (*253)
1/0
0
0
0
0
224-268 (*253)
Normal
*2
1/0
0
1
0
0
179-223
Down
*2
1/0
1
0
0
0
269-313
Up
*2
1/0
1
1
1
0
160-204
NZ
*2
1/0
0
0
1
0
288-327
UK
1/0
0
0
0
1
223-271
Normal -10kHz
*2
1/0
0
1
0
1
178-222
Down -10kHz
*2
1/0
1
0
0
1
268-312
Up -10kHz
*2
1/0
0
0
1
1
159-203
NZ -10kHz
*2
1/0
0
0
1
1
287-326
UK -10kHz
* code goes up to 253 for 23 channel radios.
*2 please notice the reversal of A7 and A8 and the different NZ/UK band programming for this code range.
Also notice the difference in 10 kHz shift, in this code range it is a -10kHz shift !
NOTE: the output codes may say a figure greater than 256, the EPROM can only supply a code as high as 255, that is why we must pull the PLL pin 7 high/low as needed to give the final code of over 256, for example, a code of 300 requires all 8 bits from the EPROM and 1 more bit (the 256 bit) to be high as well, so we pull pin 7 high as it is the pin for a code of 256, I hope this helps to explain it for those people who know that EPROM's only have a possible output code of 255.
Programming
Here are the general functions of the EPROM's A6,A7,A8,A9 and A10 inputs (may vary with input code range of radio, see above chart for more details):
A6 = 7th line of programming from channel selector, also is responsible for correct codes, normally just tied high or connected to 7th line of the channel selector output.
A7 = Down band selector (Up band for radios using 224-268 code range).
A8 = Up band selector (Down band for radios using 224-268 code range).
A9 = NZ/UK band selector (used in conjunction with A7 (NZ) and A8 (UK)
A10 = + 10 kHz shift (- 10kHz shift for radios using 224+268 code range).
Calculating the binary code
If you do not know how to calculate the binary number (also known as N code) read this.
PLL pin number
15
14
13
12
11
10
9
8
7
Binary weight
1
2
4
8
16
32
64
128
256
So if pins 8,9,11,14 and 15 where high (at 5V) and the rest where low (at 0V) you would have a binary code of 211 (128+64+16+2+1=211), you just ignore the pins that are low.
Example modification
1. I checked the PLL pins and found that it only used 1 set of codes, 255-211.
2. I decided that I only wanted to have a 10 kHz shift and the Down band.
3. I checked the programming chart and found that for a code range of 255-211 the 10 kHz step uses A10 and the Down band uses A7.
4. I cut the A7 and A10 tracks on the EPROM board (at the thin part of the track) to disconnect them from 0V which allows me to control the inputs on those pins.
5. I cut the tracks on the radio PCB for PLL pins 15-7.
6. I made available the switches required for the new functions and wired them to the EPROM board as shown below, the Down band switch is also switching the PLL pin 7 high when on, this is to increase the binary code on the 9th bit as the EPROM only has 8 outputs:
            +10kHz   Down band    <---Switch function
              ___       ___
   0V <======|=O=|=====|=O |      <---Function OFF(switch up)
   A10 <=====|=O |     | O=|====> A7 and PLL pin 7
   5V <======|=O=|=====|=O |      <---Function ON (switch down)
              SW1       SW2
7. I connected the EPROM inputs to the channel selector side of the cut tracks as shown below (this is for A0-A5, A6 can be tied high at 5V on the EPROM board):
PLL pin number -->     15  14  13  12  11  10
Tracks ----->           |   |   |   |   |   |
Cut in tracks --->     === === === === === ===
EPROM inputs A0-A5-->  A0  A1  A2  A3  A4  A5
Connections             |   |   |   |   |   |
to channel selector --> O   O   O   O   O   O
8. I connected the EPROM outputs (D0-D7) to the PLL pins as follows:
PLL pin number
15
14
13
12
11
10
9
7
EPROM output number
D0
D1
D2
D3
D4
D5
D6
D7
9. Then I connected the power wires (+12V and 0V) from the board to the radio.
10. I double checked all of my wiring, checked that I had cut the tracks correctly on the EPROM and radio boards and that I had got the input and output connection the correct way around etc.
11. I slipped the EPROM board into its heat shrink tube to protect it.
12. I turned on the radio and checked for both normal operation and the new expanded functions I set up (+10kHz step and the Down band).
13. I checked to make sure that the EPROM board was not receiving a 12V supply after I turned the radio off.
14. All was working correctly so I applied heat to the heat shrink tube to finish the installation.
15. I did not need to broad band the radio, so I have finished the installation.
16. I closed the radio back up.
Trouble shooting
EPROM is not working at all
Check jumper on pin 21, for a EPROM marked as a 2716 the track to it should be cut and the pin should be jumpered to the +5V rail on the board.
Check that you have not miss-programmed the jumpers or switches, 1 incorrect jumper or selection setting could stop the EPROM from recognizing the binary codes
The radio does not use the correct binary codes required for the EPROM to work in it, see note about binary codes that are supported earlier in this manual.
Only some bands are working
There could be a mistake with the programming switches not giving the EPROM either a 5v or 0V signal, or a jumper has not been cut or added correctly.
You did not notice that the radio uses more than one set of binary codes and you have not set the switches / jumpers for the other codes.
Some channels do not work on a certain band
If there is a large gap of channels missing it may be a jumper or switch programming problem.
The EPROM may have been damaged by static electricity during handling.
The EPROM may have been damaged by incorrect wiring.
Note: All EPROM's are checked after I have programed them to ensure that they have accepted the programming information correctly and that the EPROM is not faulty.
E-mail me if you have any questions or concerns about installation.
All boards are installed at your own risk,
(it is not my fault if you make a mistake and damage your equipment).
I build and test these circuits myself before shipping them, so I know that the boards are working correctly when you receive them.
This counter shows the number of hits since the 25th April 2001
Go Back To The Add-on Sales Page
Go Back To The Sales Page
Go Back To The Home Page
