Radio Make and Model:Ham international uk /same rig as Colt 444
PLL Number:LC7120
Test gear available:Volt metre
Symptoms:out of frequency on FM
What is working:All other modes
What has been tried:nothing
Did it suddenly happen ?:just bought rig
Anything else that may be of help?: component L15 looks damaged
haminternational uk /same as Colt 444 out of frequency on FM
Re: haminternational uk /same as Colt 444 out of frequency on FM
Hi John,
Welcome to the forum.
When you say it's off frequency on FM, do you mean the UK FM or high band as it is on that radio.
If so then adjust TC5 (the tuning capacitor) on the sub board on the left with the crystals on it and you may need to change C158 to a lower value, they are next to each other.
You'll need a frequency counter to do the job.
PS. L15 might look damaged but may still be working OK.
thanks for the info m8 trimmed the tc5 and it seems to work so thanks again (for your info it was just mid band fm)
