okay i have a cobra 148 gtl...mb8719....
i want to put this radio on frequency...a question i have...
where are the test points?? i cannot see them on the board.
is there anybody who has a list of all the test points, and their locations, for this radio??
Test Points in cobra 148gtl
- Heavy User
Re: Test Points in cobra 148gtl
They are just below the transformer on the right side about midway down.... A purple and I think it is a green wire are attached to them.... These are not like the test points in the 3600 and 6900 board radios, these are 2 small pegs sticking up from the board and the wires slip over the top of them....
- Heavy User
so are these the only two that are important??
i have since found a diagram that lists em
yes, these are the only 2 needed to bias the driver and final.... I believe there are others for PLL and noise blanker too....
- Heavy User
thanks a bunch 1096
I thought you wanted the test points for adjusting the frequency not the bias.
You should find the information your after on CBTricks under radio information.
- Heavy User
i have since found them on the site...zodiac wrote:I thought you wanted the test points for adjusting the frequency not the bias.
thanks for the heads up though
