Test gear available: 3 way power meters. Dummy Load. Test Meters.
Symptoms: The liquid lights do not respond to receiving stations on SSB Mode only
What is working: Everything
What has been tried: Visual Inspection . Made sure all connectors were pushed in.
Did it suddenly happen ?: About 1 week ago.
I have a friend that just picked up an old school RCI2950 Non DX. The Radio works Great. One problem is that when he goes to ssb mode the liquid lights to give radio checks does not register. The receive on the Radio is great. Just only in ssb mode will it not read. AM and Fm No Prob. Any Ideas to help my buddy would be great. By The way I had a channel Guard installed. Made by Lou Franklin. Prevents Adjacent Bleed over which is common on these radios. Capacator 72 was removed and 2 wires installed from the board went there. I believe its the IF strip of the radio. One wire to ground and another wire under the board to tap in to Voltage. Thanks Guys............
