PCB Number: Main board PB-111AB
PLL Number: PCB PB 121 AC HCT 58 NY 94V-0
Test gear available: F-Counter C57
Symptoms: Off Freq, on USB RIT is standing on 9 clock
What is working: Tx Am/Fm/Lsb/Usb/Cw Rx Am/Fm/Cw/Lsb Usb off freq,
What has been tried:Tried to adjust the Pll-board Tp 304 unstable 32,31000 to 32,65000 Mhz Tp 306 unstable 11,33900 to 11,62400 Mhz Tp 303 6,5 volt adjusted from 3,08 volt.
Tp 1 Cw ok in freq been able to adjust,
Lsb ok in freq been able to adjust, Usb not ok in freq not able to adjust freq fixed on 10,69405 Mhz nothing happens when I try to adjust L116
Did it suddenly happen ?: It have been stored for 10 years and It was working then.
Anything else that may be of help?: I did a misstake I shorten one off the MC301 so now Its only have one on D102 no D101.
Regards Per Andersson
PRESIDENT LINCOLN
