Radio Make and Model:
Test gear available:
Symptoms:
WHAT OTHER FINALS CAN I USE IN PLACE OF THE MRF 477.
What is working:
What has been tried:
Did it suddenly happen ?:
FINAL SWAP
Re: FINAL SWAP
I have used the mrf497 hope this helps.
Re: FINAL SWAP
The sd1446/mrf455 has very similar specs and Hfe. In my estimation, i think it'd drop in. If it didn't it certainly would with a bit of component alteration. Just my $2. Hope this helps.
Re: FINAL SWAP
I replaced sd1446 finals w/ 2sc2290's in an old Galaxy linear. I found the upgrade/ replacement info in a pamphlet from RF parts and it worked very well. They stressed the importance of using 2 beta-matched finals together rather than randomly picking a couple of the same make/model.
146 GTL
D104 M6B
2/2290's in a box
Wilson 1000
D104 M6B
2/2290's in a box
Wilson 1000
