Galaxy 44 No Modulation,
farmer
Post by farmer »
Radio Make and Model: Galaxy 44
Test gear available: Volt+Ohm Meter Watt+Modulation Meter
Symptoms: Varible Doesnt Work + No Modulation
What is working: EveryThing But Varible +Modulation
What has been tried: Nothing ,
Did it suddenly happen ?: Yes
Anything else that may be of help?: Everything Worked Perfect Until I Hit A Big Pot-Hole In The Road.Now No Varible With A High Dead Key +No Modulation. Maybe A Bad Solder Joint Thanks To The Pot-Hole.Any Help Would Be Great And Needed =D>
farmer
Re: Galaxy 44 No Modulation,
Post by farmer »
Hello, I Just Found The Problem It Was A Bad Solder Joint. A Good Magnifying Glass Makes It Alot More Easy To Find. :dance:
