Squeal on TX, only when watts are low.
Pepe Le Pew
- First Name: Michael
I have a Cobra 142 GTL that will squeal when you turn the key watts down below 2 watts. This only happens on TX. Any ideas would be helpful. Thanks.
Pepe Le Pew
Re: Squeal on TX, only when watts are low.
ok, It wasn't as bad of a problem as i had originally thought. Adjusted the ALC pot, and sprayed some cleaner on it. It's fixed now.
