I have to get my photos ready, and post some current results so far with the MFJ-259b. Some of the numbers look good.
Curiously, I am finding that unlike the complaints of the SWR shifting with power applied to the system, there is no such thing going on so far on this antenna. It is holding the 1.1:1 SWR with the meter in either case.
I am working on it at only 8' above ground so things could go South raising it up. We'll see. It's nothing special, 4 radials and a vertical radiator.
I have discarded the idea of using a Gamma on it, and may revisit the dimensions for the Maco style loop. Right now, the only thing working well is a tapped coil.
So far:
Initially, I'd used this coil which was half the spring from a Dachshund wiener dog letter holder.
Dimensions - 3" x 1.25" x 9 wraps
2.0:1 SWR limits using a small coil:
The current Matching System is a large coil:
Dimensions - 6" x 3.25" x 6 wraps.
For those interested in the 2.0:1 SWR bandwidth using the large coil.
This coil was first manufactured for use on one of my mobile antennas. It was brake line coiled up for use on the antenna.
As can be seen on the analyzer, the bandwidth improved with the use of the larger coil.
and one of these:
