Hello!
I have a question about export model of president George and usage of amplifier to it.
The amplifier i have only tolerant 6w input and the radio have 15w/fm output...the problem is how much do the radio give in output if the powernob is on minimum and middle? Don't have a powermeter to reader the output on the radio and i don't want to break the amp through overload it.
Please can someone with a George read of the power on their radio!!!
Thanks
Question about export model of president George?
If you have bought the radio and amp. Spend a little more and get your self a meter and see what it is at. That way you will be sure not to over drive the amp. How can anyone tell you how much your radio is doing with out seeing the radio on a meter they can only give you a guess just like you can.
Some advise get a meter that will read more than the amp will do. And adj so that you dont hurt anything.
Sorry if that sounds scarcastic but there is no really other way to put it
Hope that help ya 73's
Okey a good powermeter and SWR-meter...
Okey a good powermeter and swr-meter it will be after i payed all the bills this month. Some good suggestion of a cheap but decent, all in one power and swr meter?
Zetagi HP202
Okay i have find a Zetagi HP202 for only 299 Swedish crown...only to order!!
Edit : picture on Zetagi HP202
