Radio Make. Galaxy
Radio Model. dx 73v
PCB number. ept360014b
PLL number. mc145106p
I have 2 radios doing the exact same thing. When I put it on a channel and key up, it transmits on that channel. When I let go of the mic, it returns to the "fixed" channel. (6, 19, or 21) When I key it up again, it will go back the channel I selected, then 2 seconds later, back to fixed. I tried all the fixed channels and it will return to whichever channel the switch is on. I hit all the solder joints on the channel selector board thinking maybe a cold joint. These have both been converted. Any other suggestions?
Galaxy 73v
- speedracer6g
- Light User
- First Name: Michael
Re: Galaxy 73v
i have on of those here in my shop and that threw me off a little bit. I think it has to do with dual watch option. if you turn it off you should be able to use the radio normally. Let me know how you make out.
MIKE
MIKE
