Your opinion on Antennas
Mr Lee
Post by Mr Lee »
Anything out there today similar to the Big Stick, or any good all around base antenna, height is not a problem, width is a little tight, I think beams are out of the question. Also if i get into Ham is there a one size fits all antenna, cb and ham.
I looked at Solarcon, Patriot, Bandit, SIRIO GPA 27-45, SIRTEL S 2000 GOLDEN, PT99 Proton and so on. You all have so much more experience and are up on the latest gear.
Regards
Would this work ???
fatdude1
Post by fatdude1 »
hello fellow michigander my self i would go with the maco V5/8 its tune able for 11 meters and 10 meters as well as other bands but tune it for one and use a antenna tuner for the rest of the bands
hope this helped ya 73's
oh and no on the rabit ear's
bullwinkle
Post by bullwinkle »
I'm in the same boat as you. I have a loaded vertical whip with radial leads and top hat. Now that I have this mounted; I'm wondering if I shouldn't have spent more planning on the antenna. The antenna I use is a mobile 67" Master Blaster on a 11' aluminum paint stick as a mast using a 3 way mirror mount to secure and ground the antenna. I don't have much room either for 45 degree radials or anything that gets too close to gutter pipes. I found that 2- 104" pcs of 12g high tensile wire clamped to my upper mast gave me enough reflective ground plane to get out as far as 30 miles on a clear day with just a peaked radio. I trimmed the 104" wires maybe an inch or two to get it dialed in.
I too am interested in Ham bands but; Think I'll pass for now as these guys seem real stuffy about thier radios. I might play on the export CB channels on 10 meters in which case; I might have to adjust my antenna lenght a tad for good SWR. Let me know if you try any of those antennas you mentioned. I too would like to know how they measure up
DX-959
Base
Master Blaster antenna with 102" radials added
Mr Lee
Thanks guys, Hello Michigander and Ohio neighbors
Post by Mr Lee »
Trying out the Bandit II 3 6 foot fiberglass sections, the top section has a loaded coil. Mounted to a pipe that is attached to a former Tenna-Rotor, rotor disconnected. Height is about 60 feet from ground to tip. Just about ready to hook up base unit, looking for a way to get coax into house, older house, aluminum siding, plaster walls and ceilings, don't want to destroy this old farm house which we are restoring now. Any suggestions most appreciated.
Latest Toy
Vintage President Zachary T
Galaxy Echo Mike with Roger Beep
Just bought a Royce 682 mobile (like new)
Royce 619 base still in the box
Contemplating something in a new radio but not yet decided.
Lee
bullwinkle
I think the best thing to do is put in a jack on the inside wall like your cable company or phone company does. All you do is get a 5/16 drill about a foot long at the handware store and drill through the wall from the outside and then terminate the coax end leaving enough wire to pass through the wall and make your connection. Make sure to seal the outside with RTV so water can't get in through any gaps. Also check and double check for wires before you drill. I would use a stud finder and drill between two studs. I used an existing hole from an unused cable TV jack and it worked out nice and clean. I even was able to use the cover plate from the old TV/cable just drilling the hole out bigger for a female connector.
Any how; Sounds like your up there @ 60'! Your line of site should realy be nice. Are you in hills/mountains?
DX-959
Base
Frequency
Post by Frequency »
As for me, I'd go with the maco V5/8 as well.
______________________
Walcott CB - Get Catalogs and Brochures of Walcott Cb Sales Inc.
r4uconifer
groundplanes
Post by r4uconifer »
Frequency wrote:As for me, I'd go with the maco V5/8 as well.
  • nnnnccc
johhn
re;ant
Post by johhn »
Yes another vote for a Maco 5/8 $ 71.95 at H&Y electronics..
Got one myself could'nt be happer. I'm no BLEAD stick... :P
johhn
Re;ant
Post by johhn »
O.K. I used the Bandet Procom patorit , a real piece of .......
DO NOT waste your hard earned money...Mine is for sale.
They will not do 20 miles.. johhn :evil:
johhn
Re;ant
Post by johhn »
Tumbleweed
Post by Tumbleweed »
I MAX 2000
Tumbleweed
Animal
Post by Animal »
Imax 2000 (with groundplane kit) or Sirio 827 both have a superwide bandwidth, excellent performance & stand up well to the riggors of a hard winter. The Sirio works well on 20 meters too & can be tuned anywhere between 30Mhz & 14Mhz with an ATU although it's efficiency is reduced the further away you get from it's resonant frequency :twisted:
