BELCOM LS102 TUNING FAULT
soundmanjim
Hi Guys.
still didnt get my superstar 7000dx - got lost in the post - at least i got a refund!!
Anyway: i now have a belcom ls102, which is fine EXCEPT the flippin' thing will onl;y tune UP in frequency - even when i turn the tuning knob anticlockwise, it still tunes up.
whats gone wrong there? any ideas? It has been modded to cover 26-29Mhz.
any help would be greatly appreciated!
seeya
Jimbo 26CAT23
seeya
Jimbo 26CAT23
Re: Belcom LS102 tuning fault
Have not seen one of there radios for over 20 years. I still have one some ware.
Common fault IC312 (MC14011B) Quad 2-input NAND Gate or it's one or two of the IC 306,307,308 and 309(MC14510B) BCD up/down counters. you can check to output of the MC14011B but you will need a Scope to see the pulses one side of the gate is + going and the other is - going, or dry joint on the VFO PCB. Hope this helps. Let know now you get on.
soundmanjim
soundmanjim
soundmanjim
Re:Belcom LS102
I will see if I can find the service manual. I know there some Coils you do not want to adjust or you will have a lot of trouble on your hands with out the right test gear.
Rick (Euro Radio Co).
soundmanjim
mike-g7bnf
- First Name: Mike
know the radio very well
there are two presets like ears very close to the phot interupter wheel
slightly adjust one of the presets that should cure the up/down error
if you wish the service man + my notes from the last 20yrs ill put them on yousentdit.com just ask
new email as from 2018
gm7bnf@yahoo.co.uk
...tnx - mike
mike
gm7bnf@yahoo.co.uk
...tnx - mike
mike
Last edited by mike-g7bnf on Thursday 30th Aug 2018, 21:56, edited 4 times in total.
Belcom LS-102L
Mike,
I could use that info you have on the Belcom - my problem is similar to Soundmanjim's but mine corrects itself once the radio has warmed up.
Any info would be greatly appreciated.
Belcom Tuning
Thanks for the suggestions - I'll have a crack at it at the weekend & let you know how I get on.
