Pace 8046 No audio
Sirgo
Pace 8046 No audio
Post by Sirgo »
New to cb's. Recently purchased a Pace 8046 from ebay was told everything works fine. Get package home and hook it all up. Eveything turns on, turn the channels no sounds. Meter on CB moving indicating rx tx still no sound. Connect to extension speaker still no sound. any ideas?
pace 8046
serial # 12610533
# on circuit board az00844a or 6y17 30-b
don't no what a PLL # is
ouxly40
sound
Post by ouxly40 »
The mic can be the problem. The external speaker jack can be the problem. When you transmit, is there modulation? If not it's the audio chip or in case of 2 transistors one will be bad.
Re: Pace 8046 on RX audio.
Check the volume control it's is a weak point in this radio.
