Best Mobile Antenna? (Mobile Beams?)
I am trying to find out what mobile anrenna is the best for both TX and RX. I have tried wilson 1000, firestick, skipshooter and a few other lesser knowns. So far I think the wilson is probably the best. If anyone knows of a better brand or model, please advise. Also, I am trying to find out about mobile beams. I have seen two sets of these. A truck driver had one and and I saw one on an rv once. I confirmed that it was actually a cb antenna while talking to the truck driver on the radio. I can't seem to find any info on the web. If anyone knows about them, please let me know. Thanks.
Woodstock told ya that an iiiii'm baaack out!
ouxly40
Antennas
There is not really a better antenna. The best antenna is the one that works best on that vehicle. Wilson 1000 is good but does not always do well in some applications. Try several ones and see what SWR you get and compare field strength from each.
Phased antennas are basically beams. You can determine the direction of radiation by phase delay in the feed line.
The Wilson is by far the easiest antenna to use. For the ease of use it's the best. The one with the magnet and coil at the bottom. It's a shunt fed, inductor loaded 5/8 wave mobile. Which means it has gain.
Other then that. A 102" whip.
r4uconifer
kc8mob wrote:Phased antennas are basically beams. You can determine the direction of radiation by phase delay in the feed line.
Sirio Hypower 4000
Sirio Hypower 4000
i found this to be the best yet hope this helps
Francis Maser is an EXCELLENT Antenna. I had an old 72 Maverick with a tweaked Midland 77-117(not the best but did do good on the bench), and used a francis maser(102" in a ball mount) in the location for the radio antenna, and I was slamming it out EVERYWHERE. A friend of mine did me a REALLY HUGE favor, and I had nothing to put my radio in so I gave the setup to him for his motorhome, and he was blasting out everywhere too. I tried that antenna on several radios and cars, and it always worked beautifully. Only downside is it's fiberglass, so if you run TOO much power through it from a big amp you'll blow it apart.
frogman296
- Heavy User
vintagetech
Here is a beam that works extremely well. We designed, built and installed this and the first ground wave contact we made was almost 90 miles as the crow flies. So mobile beams are not junk they work very well when properly done. The reflector is on a quick disconnect so it can be removed when traveling in town but works realy well on the highway.
Dennis
Platteview Custom Radio
Dennis
- 011.JPG (174.62 KiB) Viewed 16657 times
Re: Best Mobile Antenna? (Mobile Beams?)
Hellos. hows u doing . what is the price of this mobile antenna. wheere to get the best mobile software. with all the information about the installation. dose it compatible with the previous handsets?
