Need advice for car setup
For any general discussions, if your posts topic matches one of the other forums do not post it in here, use the correct forum for the topic.
jparris
Post by jparris »
Hello all. I am looking to buy a CB radio for my car. I had a handheld Cobra HH28 and it didn't work out very well. I bought an external antenna from radio shack(the kind that sticks to the window), and it did nothing for me. My problem with magnetic antennas is that my car is fiberglass and I don't think it would stay on at 80mph. I don't want anything that requires permanent mounting on my car. What do you guys recommend that I do? Is my best bet a handheld? Any suggestions would be extremely helpful to me. By the way, I just want something with good range, not to necessarily have great talking power. I appreciate you guys time.
-John
rebelcowboy
Post by rebelcowboy »
You could try a trunk mount antenna as you said you drive a car. They clip to the lip on the trunk next to the rear window and get a mobile radio they are always better my girlfriend has a trunk mount and a cobra 29 and can get around 10 miles distance as far as i know. Good luck
Ron Fouler
Post by Ron Fouler »
Yup, lip mounts are good. I have one on the tailgate of my VW Golf, and that's very stable. Remember to scrape the paint off where the grub-screws clamp to the lip, though, or you'll have problems with VSWR.
I'm NOT Satan: It's 2 six's and a 9!
26-LB-6
Frequency
Post by Frequency »
I have to agree that using mount antenas for the trunk lip would work.
______________________
Walcott CB - Get Catalogs and Brochures of Walcott Cb Sales Inc.
JOHNNY BE GOOD
lip mount antenna
Post by JOHNNY BE GOOD »
I thought that he said his car was fiberglass doesn't that lip mount need a metal surface to get a good ground for receive or do you have to buy a special antenna that doesn't need a ground. :?:
kc8mob
Post by kc8mob »
Well most cars are not as fiberglass as you think. Panels, yes. roof and all of that, no. Hopefully.
Because if this guys car is really all fiberglass accept for the frame. He isn't going to have any luck with any type of mobil installation besides a handheld.
Mobile antenna systems require allot of ground plane to be affective.
dvdljns
Post by dvdljns »
Use a trunk mount than run a ground wire from the coax sheld to metal frame. it works good.
RW023
Post by RW023 »
dvdljns wrote:Use a trunk mount than run a ground wire from the coax sheld to metal frame. it works good.
a good ground plan works :roll: 8)
thetnhillbilly
Post by thetnhillbilly »
Aren't there antennas for RVs? Some of them are primarily fiberglass. Maybe one of those would work.
