CB channel use in NZ
For any general discussions, if your posts topic matches one of the other forums do not post it in here, use the correct forum for the topic.
lbcomms
Post by lbcomms »
Hi all,
Over here in Oz there is a loosely defined system of channel usage:
1-7: General AM
8: Truckies
9: Emergency
10: General AM
11: AM call channel
12-15 General AM
16 LSB: SSB call channel
17-34: General SSB
35 LSB: Secondary SSB call channel
36-40: General SSB
Question: Does a similar scheme exist over there in New Zealand?
If so, can someone fill me in on the channel usage over there?
Cheers from Oz!
RW023
nz channe
Post by RW023 »
from ch 1 two 19 is all am ch 11 is am calling ch and ch 15 am calling ch ./so from 20 two 35 been a call ch two ch 40 l s b :roll: :)
TrumpyNZ
First Name: Mike
Post by TrumpyNZ »
As a rule:
Ch 11 is the truck drivers channel.
Ch 15 is the Emergency Calling Channel.
Ch 19 is the AM Calling Channel in some areas.
Ch 25 is the lower limit of the SSB part of the band.
Ch 35 is the SSB Calling Channel (USB).
