Galaxy 959 10kc mod question
Hi all,
http://www.cbtricks.com/radios/galaxy/d ... kc_mod.htm
Does anyone know if the SPDT switch is a ON/ON or ON/OFF/ON switch?
Thanks
UncleT
Thanks
UncleT
frogman296
- Heavy User
Re: MB8719 10KHz jump.
My diagram on CBTricks maybe easy to understand. Check this link.
http://www.cbtricks.com/members/rick_eu ... c_jump.pdf
Hi Min,
Mater-o-fact I just picked up the parts today. I think I'm going to go back and get a flip switch instead of the slide switch. After playing with the slide switch I think it may be hard to find the center position while driving. Plus you only have to drill a whole for a flip versus cutting a square for a slide.
I probably will not touch the radio till after x-mas. I had time tonight but instead fixed my home stereo that got hit by lightening.
Have a good holiday.
Well I got the 10kc mod done.
It basically gives you 5 new frequencies to use.
26.955 (channel 4, switch down)
27.045 (channel 8, switch down)
27.095 (channel 12, switch down)
27.145 (channel 15, switch up)
27.195 (channel 20, switch down)
Cheers.
Thanks Rick for the additional schematic.
Cheers.
Re: Galaxy 959 10kc mod question.
The 10KHz switch is only to give you the A channels 3A, 7A, 11A, 15A and 19A, and the channel switch giver you the rest. What was you expending to get?
frogman296
- Heavy User
Rick wrote:The 10KHz switch is only to give you the A channels 3A, 7A, 11A, 15A and 19A, and the channel switch giver you the rest. What was you expending to get?
can this mod be done in addition with the "2 switch" channel mod for the mb8719?? the switch on pin 10 and the switch between pin 11 and 12
reason i ask is... the 2 switch mod...doesn't give 27.4450...it does give 27.4550... ideally i want to have " channel 44 "
thanks in advance
frogman296
- Heavy User
anybody?
goffiefarmer
