Palomar Skipper 300
WR954/AK944
Palomar Skipper 300
I have a Skipper 300. It is 1 - 6LF6 driving 3 - 6LF6's. The caps. blew and I replaced them (2 - 450V 67mf to 450V 100 mf and 1 - 25v 1000mf). I also replaced three diodes and both transistors. The relay was rapid firing then the caps and diodes blew. Now the caps hold and I have proper voltage (17V) to the 25V cap. However, I have no power to the operate/standby switch so the amp will not kick. It powers up, the tubes warm up and all else seems to function. Any help appreciated. Thanks.
World Radio 954; American Kangaroo 944; QS954.
WR954/AK944
WR954/AK944
proper voltage
The two large caps should have a total of 600 to 800 volts . sounds like a miss measurment or take from the low voltage section . on average all tube equipment runs 450 volts or higher on the power tubes . if you are not getting this voltage range than you may still have a power suply issue
WR954/AK944
I have been working with 2600 on another site on this amp and he has been extremely helpful in assisting me to understand exactly how a tube amp operates and it's operating compnonents. I am now down to replacing 3 items that deal with the pre-amp keying circuit and now understand why and how these component failed. Thank you for your response.
