I HAVE A PRESIDENT GEORGE..WHEN POWERED UP ALL IT DOES IS SCANS THROUGH THE CHANNELS?? IT WONT STOP UNTIL I KEY THE MIC,
THEN AFTER A FEW SECONDS IT FLICKS THROUGH CHANNELS AGAIN??
DOES ANYONE HAVE ANY IDEA WHY AND WHAT COULD CAUSE THIS?
I AM TOTALLY STUCK....MY RADIO IS UNUSABLE!
ALL HELP IS APPRECIATED..
THANKS
RICK.
PRESIDENT GEORGE........SCANNING??
Re: PRESIDENT GEORGE........SCANNING??
recently i bought a george with same problem.
"scanning" without pushing the "scan button" is caused in most cases by defective CPU.
The guy owned it befor, tried to do the "resistor mod".
Did you try to solder the Resistor near the CPU, to get the rig into export modus?
Maybe you are not careful when soldering, and one of the traces near the cpu are damaged.
I try to fix this and it works so far, that the rig did not "scan" anymore. But befor and after fixing there is no RX and TX, although the LCD is indicating, so the CPU is apparently damaged.
So it looks in my "bought used" george after i got it.
Replacing the CPU in Germany costs around 70,- Euro.
Sigi
Sigi
