President Jackson
PCB #PB042 AC
PLL MC145106
PA Final MFR455.
This model has Automatic Squelch ASC.
The output power is very low at 3 watts on AM and FM and about 7 watts on sideband. i have try adjust the power on AM with vr11 but this only turns the power down and max is 3 watts i have tested the MRF455 final and the driver 2SC2166 and are ok. i am stuck as to what to test next. Can anyone help.
James.
President Jackson very low output power
James Unit 198
Re: President Jackson very low output power
Check the bias on TR503 and TR502 you may find R241 o/c this is not uncommon. If it's o/c then change the driver (TR503) and C195. Let us know how you get on.
James Unit 198
Re: President Jackson very low output power.
Try replacing C192 (390p) use a good quality cap mica is the best, it maybe best to replace C195 with mica type. I know the radio original caps were disc ceramic but to make the PA more reliable use mica type.
Check the bias, and if necessary re-set the driver for 50ma and the final for 120ma on mode SSB with the mic gain at minimum, TP9 and TP8 for Driver and TP9 and TP7 for Final.
James Unit 198
