No TX Reading on meter
Renegado
Post by Renegado »
I have no TX power reading on my Galaxy 66 meter, please help
Post by ramblingman »
hi there...does it register on rx and no tx..or is it not working in either
Renegado
Post by Renegado »
HI, yes is working on RX real good, but doesn't move on TX, radio shows 10 watt dead key reading on the bird meter
check diode d-66 for open or short..d-66 is the rf meter detector...but first check vr-8 variable resistor to see if it is adjusted right..vr-8 is the adjustment for tx meter...if it has no effect check d-66..also check vr-8 for open condition..and also check to see if solder connections are good at vr-8..if all check good..then check c-164 for open condition
hi there...it seems i made a boo boo,,the diode for the rf detector is d-86 not d-66 i misread the schematic...
Renegado
Post by Renegado »
Wowww, thanks for your Help, just replaced D-86, and C- 164, now the meter works real good as before, thanks again.
