Well I just about pulled my hair out tonight.. I had a Cobra 25 night watch sitting about the shack along with a bunch of blue displays that just came in this week. So i was like let me toss a blue display roger beep and echo into the 25, I started with the display first.. I pull the radio down and solder the display in place and power the radio up.. and nothing.. i was like man did I put it in upside down.. so I pull it back out and flip it over and power the radio back up.. all i get is 1 segment on each digit that would light.. So I was like man i got the display too hot.. So I pulled it back out and tested it.. all the segments are working.. so I grabbed the old display that came out the radio and tested it.. first thing I noticed is that the cobra 25 radios have a common cathode not a common anode,,, At this point I am thinking no problem.. just search the net for a blue display with common cathode.. Man it like looking for a pot of gold at the end of a rainbow to find a blue display with common cathode.
I pulled out a uniden 68 and checked the display in it, its also common cathode.
Has any one ever seen a cobra 25 or uniden 68 with blue display, or does any one know where to get a dual 7 segment 16 pin common cathode display at?
Blue Display Cobra 25 / Uniden 68
- kilowatt68
One thing life has taught me: if you are interested, you never have to look for new interests. They come to you. When you are genuinely interested in one thing, it will always lead to something else. "Eleanor Roosevelt"
Re: Cobra 25 Blue Display.
The number of the common cathode 7 Segment display is 4023BA. Try the links below,
http://www.roberts-etronics45.com/led424234.html
http://www.westgateparts.com/cgi-bin/li ... ING+DIODES
I get my ones from www.jtronix.com but they may not sale to the public.
Use a 2K2 dropper resistor or the the display will only last a short while.
- kilowatt68
Thanks.. i will check with MJ Products today to see if they have them.. i was up late playing with this stuff last night..
I do you have a number for www.jtronix.com there is no info on there site.. most places will let me set up an account with my SS# as the tax id.. as I buy a good bit of stuff I repair a lot of electronics, just getting back into CB have not worked with any of this stuff sence shool days
