bord number jpmxx0276d
delta force magnum am/fm/ssb/pa 10m mobile
got low power less than 1 w damaged due to hi SWR res number 376 22 ohm getting hot tested zener diodes there ok and i have replaced both the c1969 and c2166 out put transistors and still low power
help any one got a clue
ps there is also sound coming out of speaker during tx
help please low power
What radio are you talking about?
A board number on its only will not help.
The only way we can help you is for you to help us.
So please read the info in the link below, or you post will be ignored.
www.radiomods.co.nz/forum/viewtopic.php?t=312
magnum delta force 10meter
hi the cb is a magnum delta force 10 meter cb that is all no i dont no the pll number any help
[/quote]
