COBRA 25 NIGHTWATCH NO POWER
HAVE A COBRA 25 NIGHTWATCH THAT HAS NO POWER AT ALL GOOD FUSE,GOOD POWER SUPPLY JUST STARTED LEARNING ABOUT RADIOS SO ANY HELP WOULD BE VERY GREATFUL THANKS FOR ALL INFO
Re: Cobra 25 Nightwatch Dead.
The radio that keeps blowing fuses, change D17, it may look ok, but it is most likely short.
The radio that will not power up, check the voltage between Pin 1 of the audio chip IC1 (TA7222AP) and ground with the radio switch on, the audio chip is bolted to the side the chassis.
thanks for the input Rick I am getting zero voltage it does not blow a fuse just no power at all ckeck voltage at back of radio where the plug goes in and I only get like 2 volts so I changed the plug and same thing and I get no voltage at the final.audio ic,the on and off switch the power supply and plug I am using works fine on my other radios with no problem someone else said it could be the power protection diode but not sure where it is located as I am new to repairing radios but I enjoy doing it and I would like to say thanks Rick for all your help with mine and the many others you have helped out here where would guys like me be with out guys like you so thanks again for all your help and everyone elses
change D17, it may look ok, but it is most likely short. This diode is at the back of the radio neat to where the power wires are the diode is black and is a 1N4003.
