NEW COBRA 148 GTL TUNE-UP & BLUE LED'S
I just bought a new COBRA 148 GTL & need help geting blue led channel display W/ blue plastic Lens cover & blue meter light. Anyone know where i can get them ??
TNX
BRI
TNX
BRI
I Just ordered BLUE L.E.D.CHANNEL DISPLAY, BLUE LENS & RED/BLUE TX/RX LED . Has anyone done this mod before on a new 148 GTL??? Do I need to pull the whole radio apart? Any advice or installation tips fron you experts would be greatly appreciated I dont want to ruin a new radio.
Re: Cobra 148GTL Change to Blue display.
Why do you write in upper case? We can all hear you; you do not need to shout.
It is not just a matter of just change the display, you will also need to change the resistors between the display and the channel selector or you will damage the new display.
You will need good soldering skills to do this, and you need to remove the front of the radio and remove the channel selector complete from the radio so you can work on it.
No you will not need any special tools, just take it easy when you remove the faceplate and the channel selector.
