mirage 44 troubles
dakota325
mirage 44 troubles
Post by dakota325 »
i have a mirage 44 that you can move a couple of the wires in the front of the radio and the display will go out also the receive will go in and out.ive looked for bad spots on the board but i dont see any but you can press on the board and the receive will come in and out? :?:
smokinjoe
Post by smokinjoe »
Dakota325 i have seen the solder joints on TR41 crack or break from board movement do to loose screws on main board cause this problem. Sometimes it is hard to see without a magnifier glass try pressing on the board in this area to check or touch up solder joints also check for cold solder joints on the wires that you moved that causes this fault to happen. Hope this helps.
