Palomar 775 Pill Up-Grade
farmer
Post by farmer »
Hello,The Pills In This Box Was Over-Driven And The Pills Was Fried I Am Thinking Of Running Six 2sc2879 Pills Instead Of Replaceing The Two1446 Driveing Four 2sc2290 Pills.I Am Not Sure Of How This Will Work With My Connex 4300 That Has One 2290 Pill It Dead Keys 1.5 Watts And Swings About 75 Watts And What Would The Output Be.Thanks For Any Ideas.I Would Hate To Do This And Find Out Its More Box Then My Radio Can Push Thanks In Advance For Any Suggestions
Mack43
Post by Mack43 »
What you're likely to find out is your radio has more power that either of the amplifier scenarios you've described can possibly handle.
You should either get a straight 4/2879 amplifier for that radio or get radio that only produces at maximum 30 watts pep to run that amplifier.
farmer
Post by farmer »
Thanks For The Reply Mack. I Would Like To Use This Box And Just Replace The Two 1446 And Four 2290 Pills With Six 2879 But Can This Be Done Without Doing A Lot Of Replaceing Other Parts Of The Amp ?
zeppfrog
Post by zeppfrog »
i thinks you will need to remove some windings on those big ferrites and also change several capacitors. i have studied on changing my texas star from 2290's to the 2879 and studied the parts lists on cbtricks. might check some of those out on your model or look at the list for the texas star for ideas
farmer
Post by farmer »
Thanks For The Info Zeppfrog, Maybe I Should Go With Six 2290 Pills And Forget About The 2879 Pills It Might Be More Trouble Then Its Worth ???? Thanks Again,
hamguy2
Post by hamguy2 »
the fcc would love you if they got you
farmer
Post by farmer »
Hello,Hamguy Even Ham People Love Me.OOPS. I Mean Linears,
jimmyjack
First Name: Jim
Re: Palomar 775 Pill Up-Grade
Post by jimmyjack »
I think you are going to have to turn down the output on your Connex to a low 10-15 watts and build the amp w/ (2) 2290's driving (4) 2879's if you really want to use that same case and board in the (sssh) transmitter. JMO.
631up
First Name: mario
Post by 631up »
:banghead: My advise.........junk your whole rig. get a uniden 68 or 78. get a nice class c splatter box, like a davemade or a fatboy 1x4. one 2sc2290 driving four 2sc2879.
