I am having a problem with my realistic trc-449.
receive works on all modes
When I transmit with out audio the meter will read at 9 lbs.
as soon as I talk the meter drops and the unit stops transmitting. after that when I key the mike the meter will not read at all.
if I try to use the p.a. I get no audio.
I've had this radio for about 20 years and I would really like to be able to save it.
Thank you
B
realistic trc 449
trc-449
When I powered up today I was shocked to fine that the unit was working fine. I do seem to remember some dimming though when it would not transmit. But right now using both stock and power mikes across a dummy load it's working. I haven't tried it on a live antenna yet.
trc-449
I'll be sure to remember that
Thank you for your time
B
B
