Watson W30AM Power Supply
I have a Power Supply with a problem, it keeps cooking a capacitor on the regulator board, and after replacing I can see the voltage drop.
Two questions, what is the IC on the board - LM723 ?? and why is the voltage dropping.
Not a CB question but I'm sure there is place for it on here.
Bob
Bob
LM 723 Regulator
Thanks for the rapid reply, Another source has said it's a LM 324 which is of course an OP AMP.
Thanks again
Bob
Thanks again
Bob
Power supply IC
DISCOVERED IT WAS NOT A LM723, IN FACT WAS A LM324
psu,s
maybe,your on about the transformer ver''5 - 2n3055 on a ali heatsink all hard wired with very short linkings to each other and a pain to get to best i can do these links...
http://home.versatel.nl/bartsimpsons/Ha ... matics.htm
http://www.eham.net/reviews/detail/4064
http://www.nordicpower.se/pdf/MS-EP900.pdf
manson ept-25 =30amp diag not mega fantastic. pdf.
Thanks for the links, I allready fixed it after replacing all the transistors and fitting sockets for the two IC's and both the IC's while I was in there.
The fault was the 47000uf @35v electrolytic it has a broken terminal.
Now the problem is finding a replacement that'll fit in there.
Re: Palstar PS-30M
Dave,
You can get the cap from Digi-Key http://uk.digikey.com.
Check D10 known ot go leaky and ZD2.
Not a nice PSU to work on.
