fitting the new crystal for 26mhz in the 200gtl
hamguy2
Post by hamguy2 »
hi rick, got that crystal from truck cb shop uk 2 days ago ,i was just wondering is there alignment required with the clarifier control or adjustments required also what crystal do you remove to put this new crystal in for 26mhz or does the x2 crystal have to be soldered to the board or plugs into something or componenty on the board, the crystal never came with any circuit or install instructions ,thanks davids nsw australia :?: :?:
timrim
Heavy User
Heavy User
Post by timrim »
You will need to unsolder the original and put the new one in its place. I have a Cobra 200 on the bench, so when I get to work, I will let you know which one it is. If the radio requires an alignment after crystal install, it will be a minor touch-up on one adjustment.
hamguy2
info on cobra 200gtl alignment after fitting crystal
Post by hamguy2 »
hi tim rim, this is david from australia hi hows the cobra 200 alignment going its sunday nite here at 808pm ,i was wondering how you went with the cobra 200gtl alignment for 26mhz after fitting the xtal ,can you email me the info on satob196@idx.com.au,thanks david nsw australia :D :idea:
timrim
Heavy User
Heavy User
Post by timrim »
It's the crystal nearest the front of the radio, just to the left of the 3 tuning coils. If it requires adjustment, adjust T-711 for 10.2400 Mhz at the collector of Q21.
Sorry for the delay, I have been busy the last couple of days.
