IRF840?
Dino_24
IRF840?
Post by Dino_24 »
I was considering an IRF520 in my cobra 29, but what about an IRF840? I know this mosfet is capable of around 125 watts max and I certainly wouldn't expect THAT much, but would the 29 produce sufficient voltage to obtain any noticeable results?
Cobra 29/NW/ST
Cobra 29 LTD
Realistic trc-52
Realistic trc-217
IRF840?
You would turn it on, as the input capacity is hi, and a very hi impedance at 27 MHz.
Dino_24
IRF840?
Post by Dino_24 »
Thanks for the reply. I'm a genuine novice when it comes to electronics and I've not had a whole lot of experience with MOSFETs. If the resistance is high at 27MHz, would that mean that the FET would become less efficient, producing more heat than RF power?
Cobra 29/NW/ST
Cobra 29 LTD
Realistic trc-52
Realistic trc-217
IRF840?
I do not like getting to technical, but there is not that easy to answer.
Impedance is not Resistance.
Impedance is more complex than resistance because of the effects on a tune circuit.
You may find this article may help you understand impedance.
http://forum.ecoustics.com/bbs/messages ... 31527.html
