super scanner
msherren5
super scanner
finally got my super scanner up and was working good.one problem cant switch beams.took it down and had a friend of mine look at it but cant seem to getrelays to work right on it.the three relays work independenly but they dont seem to work together.i have a four pin connector on relay box and three way on control box tried wiring up 6 ways to hell and back but cant seem to figure it out any help greatly app. mike
Re: super scanner
Do you have the instructions for the Super Scanner?msherren5 wrote:.i have a four pin connector on relay box and three way on control box tried wiring up 6 ways to hell and back but cant seem to figure it out any help greatly app. mike
The reason i ask, is that i had a chance to get a damaged one (now buried in the snow)
But in anticipation i found and downloaded the Super Scanner manual, damned if i know where i found it but i have it on the hard drive as a pdf file..........would that be of use to you?
I see you are on the Island...... I'm right next door in N.B.
E-mail me direct if i can help
dredfern@nbnet.nb.ca
regards;
Dave from Canada
Dave from Canada
