cobra150gtldx no transmit on some channels
Posted: Saturday 16th Dec 2006, 13:31
by Anonymous
i did the channel mod on a brand new cobra 150 gtl dx and after the mod which opened cb band and 26.065 and up--some of the frequencies will not transmit about 2/3 ---mainly from 26.305-26.955 and 27.545-27.995 is this normal with this mod or is something else wrong??swr is perfect and everything else seems to be working
Posted: Sunday 17th Dec 2006, 5:55
by parkair
I noticed the same thing with mine.
Posted: Monday 18th Dec 2006, 13:25
by Anonymous
what can be done to remedy the problem??is there a remedy
cobra 150
Posted: Saturday 3rd Feb 2007, 15:39
by mav391
Look at r676 should be just above the site where r138 was removed during the conversion. if r676 is not there you will not be able to transmit on the frequency that you stated. if you still have the r138 then install in on the pads of r676 if it is missing.
Cobra 150 GTL DX
Posted: Thursday 29th Mar 2007, 12:48
by Woodstock
That's what I did and it transmits on all channels now. Also, if you don't have the surface mount resistor you took out to convert the radio, you can use a regular 1K ohm resistor. Be careful! The traces are very easy to overheat and lift on these boards!
