saying Hi
saying Hi
Hi to all I am just trying to set up a base set at home. I have an old cb out of a truck I used to drive and would like to get it working at home. don't know how to reduce the 240 volts done to 12, any sugestions would be helpful. email is hcbell@xtra.co.nz cheers and regards Harry
Set up a home base
Hi Herry,
You will need a PSU know as a Power Pack with a output of 13.8 volts DC and about 5 Amps will do.
Set up a home base
Try antenna like the Antron-99 which require on adjustment or any 1/2 to 5/8 wave antenna will do the job.
