galaxy 44v no audio
Posted: Friday 2nd Feb 2007, 19:23
by lugnut257nwga
can anyone help me ive got a 44v it recive great but has no audio ive tried the audio chip both the 1969 and 2166 trans but i can here myself in the talkback
Re: Galaxy DX44V no audio
Posted: Saturday 3rd Feb 2007, 2:41
If TX check transistors TR49, 50 and 51.
Posted: Saturday 3rd Feb 2007, 16:17
by lugnut257nwga
it is the tx
Posted: Saturday 3rd Feb 2007, 21:02
Check the PA is working?
If so check TR49,50 and 51 you most likely find that TR50 and 51 is short circuit.
Posted: Sunday 4th Feb 2007, 9:25
by lugnut257nwga
yea the pa is working i check the volt on the tr49,50,51
Posted: Sunday 4th Feb 2007, 9:31
lugnut257nwga wrote:yea the pa is working i check the volt on the tr49,50,51
You check the voltages well what are they
Posted: Sunday 4th Feb 2007, 9:45
by lugnut257nwga
15.10-12.40-15.10
tr49 tr50 tr51
Posted: Sunday 4th Feb 2007, 10:42
[quote="lugnut257nwga"]15.10-12.40-15.10
tr49 tr50 tr51[/quote
You have lost me.
With out getting to technical a transistor has three parts to it called Collector, Emitter and Base you need check the voltages at each pin and you need to know which pin is which. For example looking at TR51 from the front left to right is Base, Collector and Emitter, so when you check it you should get voltages like Base = 12.50, Collector = 5.60 Emitter = 13.80 this is only an example your voltages maybe different. So check TR49, TR50 and TR51 and let us know the voltages you find.
You could just change TR49, TR50 and TR51 and hope for the best.
Good luck.
Posted: Sunday 4th Feb 2007, 12:25
by lugnut257nwga
tr 49 E 6.71
C 6.72
B 15.08
TR 50 B 15.13
C 15.27
E 15.28
TR 51 B 15.29
C 6.71
E 15.80
Posted: Sunday 4th Feb 2007, 13:13
Your power supply is putting out far to hi a voltage, before do any more readjust the power supply for a maximum of 13.8 volts. Disconnect the power supply from the radio and with your test meter check and set the power supply for 13.8 volts.
All the voltages you have given me are wrong make shoe you have identify the correct pins you should be looking and check them from the front, the front is the flat side with the number on it. The transistor TR49 looking at the front left to right is Emitter, Collector and Base, TR 50 TR49 looking at the front left to right is Base, Collector and Emitter. Hope this helps. But set you power supply first and give us the voltages again.
Posted: Sunday 4th Feb 2007, 13:25
by lugnut257nwga
OK I USED A CAR BATT THIS TIME
TR49 B 11.75
C 6.66
E 6.65
TR50 B 11.91
C 6.66
E 11.06
TR51 B 12.62
E 6.65
C 12.10
THANK YOU
Posted: Sunday 4th Feb 2007, 13:45
You have a PM.
Posted: Sunday 4th Feb 2007, 13:48
by lugnut257nwga
WHAT
Posted: Wednesday 7th Feb 2007, 8:47
by lugnut257nwga
thank you rick the tr 51 was bad
