sound byte
- lugnut257nwga
sound byte
how to hook up a mule fart toy it has four wires a has a white gray blue brown wire
white -audio
blue- power
grey- ground
brown- tx /switch
thats how the ones i have used hooked up, they had the interchangable sound chips in them. ill be damned if i can rember the name of them. there cheap from a1 telecom, pro trucker or some crap like that.
if you were hooking it up to a cobra radio
audio would be pin #2 and tx would be pin#3 on the mic connector
blue- power
grey- ground
brown- tx /switch
- lugnut257nwga
sound byte
thank you i will try it soon
