magnum 257 help
magnum 257 help
i have a magnum 257 theradio will tx and rx ok but i have a deadcarrier no mod any 1 know whats wrong could it be the microphone any help please
nomadradio
Microphones break far more frequently than radios. The cord is the number one failure, especially where it enters the mike, or the plug.
If you don't have another mike to try on the radio, or another radio to try on the mke, this is a lot more trouble.
Taking apart something that isn't 'broke' could end up being 'broke' if anything goes wrong putting it back together.
Somebody (else) needs to put up a web page showing how to test a mike with only a DVM or analog test meter.
Do you have a wattmeter, so you can tell what's coming out of the radio?
If the radio's carrier power jumped 'way up when it stopped modulating, that could be a clue, too.
Re Magnum No TX Audio.
Is the radio working on FM? Have you tried for a radio report on FM? If FM is working ok then try replacing Q78 (2SB778) this is the transistor bolted to the side on the radio. Hope this helps.
