5-tone roger beep
HELTER
5-tone roger beep
Post by HELTER »
i recently installed two of these in cobra 29's one works fine all the time, the other works fine if the truck it is in is not running if you start the truck the beeps run fast and higher pitch and somewhat distorted any ideas to fix the problem would be appriciated
" YA AIN'T GOT NO THANG IF YOU AIN'T GOT NO SWANG " KEVIN RIZER A.K.A. NIGHTOWL YOU ARE MISSED
ouxly40
5 tone
Post by ouxly40 »
how much does the supply voltage change from engine off to engine running?
