install Echo Board in Cobra 29LTD
gundoctor
Post by gundoctor »
I have an echo board out of an old Galaxy 99. I want to put it in a Cobra 29 LTD Classic. The problem is it needs 8 volts for the power.
Does anyone know where I can connect to 8 volts?
Once a Marine, Always a Marine.
kc8mob
Post by kc8mob »
get a 7808 and chasis mount it by the power plug. Simpel IC voltage regulator
Show me the Linears!
gundoctor
Post by gundoctor »
Thanks. I was thinking about tapping the emitter side of TR23, but I'd rather it just have it's own with the 7808. Thanks for the input!
Re: Install Echo Board in Cobra 29 LTD classic.
You can safely pick up 8 volts at the emitter of TR28, if you need the transistor to handle more current change it to a 2SD926 with a 1 watt Zener.
nomadradio
Post by nomadradio »
That echo board shouldn't pull much more than 15 or 20 mA. Won't overload TR28.
gundoctor
Post by gundoctor »
Thanks, I'lll just pull it from the emitter of TR28 then.
