good bad and the ugly hookup
- perrym1962
I have a good bad and ugly noise toy. It has red, black, white and green wires. Just wondering if anyone knows how to hook it up. Someone gave it to me and did not have the wiring configuration for it. Thanks, Perry..
nomadradio
Best guess:
Red is power. Best source is the regulated 8 Volt or 9 Volt source in the radio.
Black is ground. Either the ground wire that comes off the mike socket, or the circuit board at the other end of that wire will work best, usually.
White is the audio out from the toy, to the audio pin of the mike socket.
Green wire triggers the recording inside. Pretty sure a push-switch to ground activates it.
- perrym1962
Thank you for your response and your time. Greatly appreciated. Perry
- perrym1962
good bad and ugly
I hooked it up as you said and it worked like a charm. Thanks again, Perry...
nomadradio
