ramblin man helppppppppp
tim_spur
hey ramblin man on the galaxy dx-44 i put another new audiochip in the way you said it goes in i can transmit,modulate and needle on my meter shows i,m recieving people talking only problem is i still cant hear anything everything else seems to be working except for the audio i tryed the factory speaker,an exteral speaker but still no sound could i have shorted something else out when the chip was in backwards awaiting your wisdom
hey bud,you need to change the shunt capacitors in the audio chip area. its always a good idea to change these,when you have to change the audio chip.especially in your case as the adio chip was installed backwards.change c-150,c-151,c-146 and see if this will get you up an going...also check c-190,often this cap.goes bye bye when a radio is hooked up backwards.which is basically what happened,installing the audio chip backwards........and as far as the talkback,in your galaxy saturn.this is a real easy mod.clip d-80.if you want to make your talkback switchable.install a spst toggle switch in series with this diode,one wire to diode,and other wire to the wire next to board where you clipped it.also you will need to install a 470k resistor from the junction of c154/r207 to the junction of c187/r235 on the solder side of the pc board.to see the location to install it...go to www.dxzone.com/cgi-bin/dir/jump2.cgi?10=2482 ramblingman
hey,that web site aint gonna work.try http://home.earthlink.net/~galaxytech/l ... lkback.jpg
Re: Galaxy 44 missing components.
The reason the components are missing is that your Galaxy 44 is AM/FM mode only. The missing components are only fitted to radios, which have SSB.
tim_spur
ok thanks there rick i was worried there for a minute i bought all the caps ramblin man said to replace today i hope it fixes the 44,66 and 88 i,ve been without them for a couple of years now theres a place near me called randolph and hale where you can buy only certain caps,resistors that you need instead of having to buy a whole pack of different values...i,d give anything just to be half as smart as you and ramblin man you two guys are my hereos
