realistic trc 449
Posted: Monday 16th Jul 2007, 12:50
by galaxy
I have a realistic trc 449, pcb# pc 176bd, with a 858pll.
no transmit on am & ssb.
it receives on upper & lower ssb, but not on am.
No in coming signal on the meter on am.
it has in coming signal on ssb.
I hear the relay working.
no output movement on the meter when i key the mic.
a brown wire with a red & white wire with sheild came off. i was trying to put on a wattage control were the r f gain was. and it shorted out . i need to know were to put the wires back. please help!!! galaxy
Posted: Friday 20th Jul 2007, 12:50
hi there,let me try to find a schematic on it.and study it alittle.and i will get back with you tomorrow.....ramblinman
Posted: Saturday 21st Jul 2007, 6:49
hello,most likely you are missing one or more of your branch voltage at the p.s.b..check tr-41.first check voltages at tr-41,and let me know your findings.more than likely youll find tr-41 either o/s.but give me your voltage readings at tr-41,and then we will proceed from there.tr-41 is a 2sc 945aq.emitter should be 8.16 in am and 0 in ssb.base should be 8.71 in am.and collector should be 9.31 v.d.c.
trc 449
Posted: Saturday 21st Jul 2007, 11:02
by galaxy
on am i'm not getting 8.16 im getting 2. on ssb looks good im getting 8.+ on the collector on am its low, but on ssb it looks good. (i for got this) on ssd everyone sounds like donald duck... thanks galaxy
Posted: Saturday 21st Jul 2007, 12:56
hi,i think you should replace tr-41,try that and see if normal operation returns.
trc 449
Posted: Saturday 21st Jul 2007, 14:45
by galaxy
sounds good on ssb, i heard myself on another radio. still no receive on am. and no output power .galaxy
trc 449
Posted: Saturday 28th Jul 2007, 17:44
by galaxy
still need help with this radio.. galaxy
trc 449
Posted: Friday 10th Aug 2007, 14:17
by galaxy
i need help with this radio. please read my post . galaxy
trc 449
Posted: Friday 10th Aug 2007, 22:30
by Chevin
Have you tried asking Rick? You would need to give a full description of what your fault is along with what you have tried to sort the fault out.
Chevin.
Posted: Thursday 16th Aug 2007, 14:10
by galaxy
help help
