How can I install lower band in cobra 29?
I know you can buy a kit to get uppers and lowers. But, I'm just curious if anyone would know how to build a kit that will get just the lower band. I think it can be done with a crystal and a few passives. But, I could be beating at the air too. I'm sure someone knows all the theroy and technical gargen. But, I need it simple. I find that theroy and tech helps. But, hand's on does me alot of good. Cause, I'm a slow learner. Lower 19, 26.735 is used alot in the USA by more curtious truckdrivers who don't care to hear all the foul and fun. THanks fella's!![/img]
Re: Low band in cobra 29.
You will need to build an External loop oscillator to obtain low band (26.515 to 26.955) see diagram. If you need any more info let me know.
Ken's Electronics have 14.910 MHz on there list at $12.00 + Shipping.
www.kenselectronics.com/lists/cbxtal.htm
or you could try one from the list below.
CRYSTEK CORP.
2351/2371 Crystal Dr.
Ft. Myers FL 33907
TEL: (800) 237-3061, (813) 936-2109
FAX: (813) 939-4226
www.crystek.com
INTERNATIONAL CRYSTAL MFG.
10 N. Lee Av. / P.O. Box 26330
Oklahoma City OK 73102
TEL: (800) 426-9825, (405) 236-3741
FAX: (800) 322-9426, (405) 235-1904
www.icmfg.com
CRYSTEK CORP.
Ft. Myers FL 33907
FAX: (813) 939-4226
www.crystek.com
www.icmfg.com
Thanks Rick, You've been a great help. I've used ken's before didn't know they sold parts too. This is great stuff. I'm amazed at your knowledge and, that you are so willing to help. Local guys here just put there noises up and snarl. 73's Hope it's all good, in your section of the Globe. YosemtySam told you that!!!
