SWR METER IS STUCK ??
Posted: Sunday 30th Sep 2007, 7:39
by belfiglioval
HELLO , i have a cobra 2000 GTL and the SWR meter is stuck at about halfway, can anybody give me some advice as to how to repair this problem? thanks.
Posted: Monday 1st Oct 2007, 11:56
by Dx_freak
On the top and or bottom of the meter itself, you will see a screw, very carfully back off the screw on the top of the meter and watch the needle of the meter while doing so. It will only take a small amount of force to turn the screw, also, if you go to far you will knock the needle off its axis so take your time while doing it, watch the needle closely and be easy with it. If done correctly and if the meter itself is not burnt out, you will free up the meter and it will work again. Remember, slowly, easly and watch it closly.
