Super Scanner 11 meter beam
I am looking for a manual for the super scanner 11 meter cb beam. I want to put it back in service. Need to reassemble it. It is all in peices. Thanks
Hi if you use search engines theres a company in your area that retails the instructions on the other hand there's info with pictures no insrucs as is, but if no joy try cb tricks.com its under the header blah150.
