question about noise coming through power line
MichaelT0101
Post by MichaelT0101 »
I have a 03 nissan frontier kingcab I have my power wired straight to battery I have tried a bunch of inline filters nothing seems to stop the motor noise coming in is their anyone who could point me in the right direction. info on noise, engine off no noise engine at idle low noise the faster the engine goes the louder the noise any thoughts how to make it go away. The filters I have used where from radio shack , pilot truck stop, and flying J.
MichaelT0101
sorry I posted in wrong place I do have anntena problem and power ploblem.
johhn
re;noise (Fuel Pump)
Post by johhn »
At your COIL there is a capacitor,You need one of them.
It may be square or round ,But it only has one wire on it.
You can use a noise cap from a set of breaker points ,also.
O.K. ,radio on loud, engine - running, lisen for noise while
you unplug your fuel pump relay.. attach too the wire running to the fuel pump ,Don't cut the wire, skin the inslation back ,wrap the cap.wire around it.(the positive of the fuel pump). now attach the screw end,
Or bracket it has with it. You may also have to do the blower motor
also. I did my Ford Taurus99year it will work like you have the key off..Very Good johhn 361 lsb 38 in texas.. :D
The points & Condencer Box I have has part #C-1000 (round)
G.M.#1972370
The Ford # for a noise capisator is F6AF- 18801-AA (Black square)
johhn
re;noise
Post by johhn »
You must find the relay for the fuel pump .On the Relay,
You will see a drawing on it . Look very close at it.
the wire that 2-spots on the drawing,(Trigger).
Or you can use a Test light the wire that has no power or ground to it ..
Re move the relay box under the box,Find the pump pos. Wire.
Wrap the caps.wire around the pump wire..attach otherend is shild or mount .
johhn
re;Noise
Post by johhn »
You have electric Fuel Pump noise ,it will run you out of your truck .
johhn
johhn
Re;noise
Post by johhn »
With the relay unplugged , the top left is key power .
The bottem right is the wire going to the pump .
Jump these two points for your test . When the pump runs,you will hear-
The noise on your radio,,,,,,
you now know how to drain or test the fuel system.
The bottem right is the wire you want,under the relay box.
