I have a cobra 148gtl dx, it worked fine and then nothing. doesn't light up or anything. power supply is fine, fuse is good, protection diode is good.
what should i check next? what could cause this to happen?
all help and suggestions are welcome...im going nuts without my radio!!
the main pcb: PC-879AA
Thanks
R.
COBRA 148GTL DX......DEAD!!
That's the MK1 with the PC 879 board in it.
Test the on off switch to make sure the voltage is both getting to it and coming out the other side of it when switched on, it could just be a dirty switch. Even with the regulator faulty the radio would still light up the channel display and meter.
Re: Cobra 148GTL DX Dead
I see you got a good response, Dave
I bet it was some think like a bad power lead or PSU.
