I am in need of information to properly set the programming pins in an old Redco UFO unit. I have the Digiscan 400 manual which is a help for wiring the unit to the radio, but I need the truth table for the program pins in the Redco. Anyone have a manual? I have all the editions of Secret Cb except volume 5, and I suspect there may be info in that volume for hookup to a upd858 Washington or similar radio. Any help would be greatly appreciated!
Old School
Redco UFO Manual Needed
Old School
If it ain't a UPD858, it ain't "Old School"
I have info on a few units,here is my first guess for the switch settings (if it is the right model):
For radios using a 11.285MHz reference frequency:
1, 2, 5, 9 = Off
3, 4, 6, 7, 8 = On
OR for radios using a 36.570MHz reference frequency:
1 - 8 = Off
9 = On
You need to be very specific about the model of radio you want to install this into, and which version of a digiscan it is, use the full name of the unit, there are several redco digiscan versions.
Providing all the information about your question saves a lot of time and guesswork by others.
1, 2, 5, 9 = Off
3, 4, 6, 7, 8 = On
1 - 8 = Off
9 = On
Re: Redco UFO Manual Needed
You can download the manual and update from here,Old School wrote:Hi,
Old School
http://www.cbtricks.com/miscellaneous/r ... /index.htm
