cobra uk 25 ltd
Posted: Tuesday 29th Jan 2008, 8:52
by davedonna
the info on the bord is as follows
cobra gr25/29 ltd st
the pa is working and it lights up ok the tx rx light is working ok
there is no receive
no tx as in no power out put at all
there is 2 bad caps c212 and c218 think it has had 24 volts throw it or reversed power
any one got any ideas thanks
Re: cobra uk 29 ltd No RX/TX
Posted: Tuesday 29th Jan 2008, 9:11
Try replacing the AF Amp, and check all the diodes as the diodes are known to give trouble in this radio when it has been zapped.
Posted: Tuesday 29th Jan 2008, 10:30
by davedonna
hi rick what is the ic number for the af amp thanks for your time
